hammer
Ihave a 19 95 M1083.IAM having problems with ALTERNATOR ON THE 3116 CAT
The alternator repair shop says that there is nothing wrong with the alternator.on the bench the green light alternates right to left correctly. But when I install the alternator there is no lights working on the alternator.
Question # 2 Were can i local a wiring diagram for a M1083
THANKS I DO NOT KNOW WERE TO LOOK
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Not sure if you meant to put your whole address for location(I sure wouldn't), but just the zipcode is more than enough.
I'm sure someone will be along soon to help with a schematic. Welcome to the site!
Suprman
677
Stratford/Connecticut
Chances are the regulator sense wires are bad. I don't know how a hammer is involved in this though. And if you hit the alternator with a hammer the only thing it will do is make your pocket lighter they are expensive. You can verify the regulator connections by running the truck and measuring the voltage at the alternator outputs then at the regulator contacts. The voltages should be similar when running. One is 12 and the other 24. The easiest way to fix this issue would be to run fused wires from the cab power panel to the regulator. One for 12 and one for 24 volt. Unfortunately there are no complete wiring diagrams that I know of. You can also run the fused wires from the polarity protector under the spare tire from the truck side of the wiring connections on it to the alternator. This is a common issue.
