Hand Operated Throttle on m1008?
cjkeeliii
Thomasville, GA
I would like to add a hand operated throttle to my m1008. Has anyone done this? Would it be better to attach it to the accelerator pedal remote control or the belcrank on the injector pump? Thanks for a great site.
1,172
Why would you need this? What are you trying to accomplish?
1,806
Don't laugh but on my 88 Crew Cab w/4sp I had a bicycle cable shift lever attached to the shifter. I got so used to using it, I would more often than not, use it instead of the gas pedal. It also had a thumbscrew you could tighten to lock the throttle above idle.
84cucv1ton
New Jersey
i have seen that too, helps a bit off road too
hobie237
Newark, DE
Helps a lot off-road for people like me who have left feet accustomed to only mindlessly stomping a clutch on and off, and have difficulty modulating the pressure on the brake pedal with our left feet.
That said, it's as simple as re-routing the cable to the location of your choosing and fabricating some manner of bracketry/lever assembly. You may need a longer cable, you may not. You may elect to run a secondary cable so you can go both with the pedal and with the lever, or you can just re-route the original cable.
CUCVFAN
Gunner's Mate First Class
53
Jarrettsville, MD
I have seen a throttle control on some M1028's that had serious comm. gear in the back at some point. These were all on the 1987 models with the 200-amp charging system. BKubu had one, so he might remember better (or, he might have a pic of it), but I think it was mounted in the dash and attached to the throttle rod that comes off the top of the pedal. Pretty neat set-up.
nk14zp
17
Columbia Falls Maine
I put one on my dodge. the type that you turn to adj has button in the middle to relese. Mounted it to the dash used a piece of pvc pipe cut at an angle then real small chain to pedal. Where ever you put it think about if you may need that space in a crash.In my avitar you can see that the cb should have been put some where else. i will get a pic of my ht for ya.
acmunro
Reynoldsville,PA
I have one on my old 6.2 plow truck. It was a GM option that was on a Pennsylvania Dept of Trans truck my father was parting out. The holes are already in the bottom of the dash to mount it. Sounds like what CUCVFAN was talking about. It attaches to the accelerator petal. I can get some pics if you would like.
cjkeeliii
Thomasville, GA
Thanks. I would appreciate some pictures. My intentions for a hand throttle were several. First, it would help in diagnosing engine problems that require the engine to run at a certain RPM to duplictae road conditions. Second, it would allow me to bypass the fast idle solenoid so that a remote starter could be added. Third, and yes, I know this is dangerous, it would be a cruise control of sorts--kind of like on a 2/12 ton. Last, it's just cool to have another control to play with. Please send any pics or ideas. I once had a '47 Willys that had a hand throttle and it was pretty neat, but I'm not creative enough to rig one up without some ideas from you guys.
Crash_AF
Colorado Springs, CO
Any commercial truck accessory shop that installs PTO driven devices (like dump trucks and wreckers) should have the proper bracketry and control components to add a hand throttle to your truck.
Later,
Joe
