llong66
- 2
- 0
- kokomo, In
I recently bought a hand throttle kit for a hummer on Ebay, as you can see in the first pic it came with all the brackets, bolts, etc needed for the instal on a hummer. It also came with a really nice set of illustrated directions. Needless to say the install was a little different than on a hummer but the basic idea was the same. I removed the gas peddle and the large bracket that holds it in place, its only 3 bolts and the whole assembly comes out, the throttle cable it held in place with a simple push/lock connector. I installed the yellow bracket that holds the throttle end of the cable on the large plate thats part of the stock throttle assembly. One hole was already in the perfect place so I only had to drill one hole for this. You can see in the 4th pic that there was a small tab bend slightly over, I could see no reason for this and had to bend it back flat so the bracket would fit. To attach the cable to the stock throttle I drilled a hole in the peddle linkage right below the factory hole and attached a small "L". Then I snaked the cable around to the left of the steering collum and simply bolted it in place with 2 bolts. I had to put a cpl of zip ties around the hand throttle cable at the end to take up space as it did not pull in far enough to do anything in its stock length. I dont have a tach yet but I am guessing that when fully engaged it ups my idle to around 1000rpm.
