Hand turn Sheppard steering gear?
tgejesse
288
Maryland
Hi all,
After 2 years of owning and staring at my truck I finally got the help I needed to change my Sheppard steering gear in my 1165.
I read a thread in here not too long ago about the nightmare that was this gear. This thing is a monster. I don’t wish a bad gear on anyone đŸ˜‚
I still have some work to do, so I cannot do a complete test…. But I was curious if those of you who know enough about these things can tell me if you’re supposed to be able to turn the pitman arm by hand?
I can on my old one, but cannot on my new one. Hoping this is good news.
Curious to hear your thoughts. Here’s a vid of the old one.
Mogman
9,560
Papalote, TX
I would expect it to be tighter, maybe too tight to turn with your fingers, but yes you have to be able to turn the input shaft or it will not steer.
If it is full of fluid and the ports are capped then it would be hydro locked and very hard to turn, why the truck is nearly impossible to steer without power assist.
Retiredwarhorses
4,177
Brentwood, Calif
That gear has specific instructions for installation, do not turn the input shaft while it’s out of the truck.
This gear uses a sesctor shaft, turning it to far in either direction can cause issues.
