Hanging Bobber Springs
farmall
usa
When hanging a front suspension out back on a bobber, what angle is the shackle supposed to be at ? Straight with a naked spring?
If I center the axle under the 105 wheel well and bolt the springs up with the shackle straight, will the position of the axle in the wheel well change when weight is added?
ranchhopper
139
south elgin illinois
If your using donor springs from another deuce measure the distance the hangers are apart on the front ones where they are rivited to the frame and set the rears the same.
