Hard gas line routing
Lindsaym151
12
Eustis,FL.
Hey all,
Im in the middle of a build and cant figure out where the gas lines route !The hard lines are all pretty bent up or full of holes!.
Im thinking of cutting the ends off and running rubber lines!
Double hose clamp all ends and I can run where I want!
If you have pics of correct routing that would be greatly appeciatted!
THX
Lindsay:???:
RAYZER
59
sanford/florida
I think you can but, if your clamping onto cut off steel line, that seems not to seal and hold as well as a barbed fitting or compression fittings.
Only my opinion though and you know I only want the best for you Lindsay! :D
