Hard start
Trouble
Burton, Ohio
Any one know why an American Bosch PSB injection pump on a LD-465-1C Hercules would lose prime after 3 minutes? There are no external leaks. I can see air bubbles in the return off thr IP for 30 seconds. Then requires bleeding just one line at the injetor.
rustystud
2,815
Woodinville, Washington
You more then likely have a small hole in your fuel line, and are sucking in air. A lot of times the hole is so small that it doesn't leak fuel, just seeps a little. Then when it is running the pressure in the lines can actually create a vacuum pulling in the air. I know this sounds funny but this is how it works. Your in-tank pump usually puts out 6psi to 10psi pressure. Then the injection pump "booster pump" pushes that pressure up to 35psi to 70psi. Since this pump is at the end of the line it is actually "drawing" (pulling) in the fuel. Think of a straw in a glass of soda. If there is a small hole in the middle you will suck in air. Same principle here. If your truck is an older model then I would recommend replacing ALL the fuel lines (hoses) . Copper has a tendancy to "work" harden then break or crack due to stress. This is one of the very first mods I did on my own truck. You can go with DOT nylon hose. It is very affordable and very easy to work with. Plus it will out-last you and your children ! I would NOT go with regular rubber style fuel hose. Most people do not realize rubber has a limited work life of so many years. Then it starts to break down.
Trouble
Burton, Ohio
That is a good thought. Has a piece of neopreme frome filter to IP. Looking for parts to replace it first. I get a lot of air out of filter bleed screw also and it is well above IP. The amount of air in system has to be displacing a lot of fuel but nothing external. Truck runs well once it starts.
