Crazyguyla
- 124
- 43
- Altus, OK
With the weather starting to cool off, I've been working on getting the power plant for the compressor unseized. After sitting most of the summer with ATF in the cylinders, Two cylinders were free, while the other four pushed their liners out. The powerplant is a Waukesha 195 GLC with dry liners. Once the liners started to budge instead of the pistons, use used liberal amounts of PB blaster around the liners so they would slid out. After a few hours of work, cylinders 1, 3, 4, and 5 slid out the engine. Piston 4 slid out of the liner after a few taps with a hammer via wood block and needs a good cleaning around the rings. 1, 3, and 5 are sitting inverted in a 5 gallon bucket, soaking in ATF. The rod bearing didn't have any serious wear, but some abnormal wearing from foreign matter being present under the bearing shell.
finding replacement sleeves seem the be NLA. If anyone knows where I might find some, that'd be great. It seems the 195 GL/DL was the only Waukesha engine at the time to use dry liners and to have a 4" bore, with a 4" stroke.
