M1028A1ShelterCarrier
- 68
- 28
- Mammoth Lakes Ca.
So I bought the RF-3183 setup and cant get it to work with a Yeasu 2m radio. The Yeasu has a bnc adapter and is plugged in the VHF port on the antenna base. I have swapped radios, cables, vhp/uhf ports, swapped antenna bases (truck has two), grounded the antenna base, with no luck. I can see/use my local repeater on a cheap portable 5W but cannot hear/key up the repeater with the 3183. Do I need something special since is has two ports (VHF and UHF). I have also tested continuity from the radio to the base. Thank you!
