Zach_M1078A1
- 42
- 18
- Utah
Has anyone ever bent their frame and if so, how and where are you able to repair it?
.Has anyone ever bent their frame and if so, how and where are you able to repair it?
My frame isn’t bent. I’m just wondering if anything stupid I do moving forward could bend it. This truck is going to be put through the ringer. I live in North East Utah at 8400 foot elevation in my entire life is outside in the mountains in the forest crossing rivers, not creeks boulders the size of a Prius. Will the flex in the frame just stop flexing at its Limit or will it bend.
Well... I guess it depends on "just how bent" your frame might be.
I am roughly 2200 miles away from you, so I doubt you need a frame that badly - but I have one. Minus the hydraulic tank and the winch that was bolted to the other side.
Might need to get more specific on exactly what I have vs what you need.
I am also concerned about sidemounted winches slowly twisting the frameHas anyone ever bent their frame and if so, how and where are you able to repair it?
Frames bend. All of them. Any of them can be twisted back by a proper frame shop. If you have more concerns then go to a double framed truckI am also concerned about sidemounted winches slowly twisting the frame
You can still bend a double frame it just takes a little effort . See it regular with michigan special tractor and concrete mixers .Frames bend. All of them. Any of them can be twisted back by a proper frame shop. If you have more concerns then go to a double framed truck
I have an M 1078 A1 so that is what I have. My concern is when a wheel has no articulation left and comes off of the ground. Will that just be off the ground or will it twist the rail to let the tire back on the ground. It’s not exactly a lightweight rock crawlerFrames bend. All of them. Any of them can be twisted back by a proper frame shop. If you have more concerns then go to a double framed truck
I think it will buff out !
I say build it ! buy some of those oshkosh steering axles out of cali and make it all wheel steer and a cucv body on it would look great.
Now thats not fair, I am sure if it had landed right side up, it would have been just fine…
This is still making me laugh!I think it will buff out !
