Has anyone put HMMWV wheels on a Dually?
4,812
Rear should work as well since the hub with is wider as well on a dually. Unless he's talking about having it "dualed". In which it could be done, but you're going to have to build some hefty spacers/adapters. And tire inflation will be interesting.
4,812
That looks pretty awesome actually.
Roveroverme, yeah that's certainly lifted. I'd say 6" at least. I did think about the rears a little more. If you were to drill a 1/2 or so hole in the rims right there near the bulge before the hub flange, you could use some of those remote air hoses for motorhomes and such. Then for the spacers you could probably get away with a set of dually front spacers on the rear. I'd see about having a thin plate made with lugnut bevels to keep the inner wheel in place. Then bolt them down with a socket and wrench. Then put the outers on as you route the hoses through. Changing tires would be a lot of NOT FUN. But it certainly would look cool.
4,812
OK, did some googling and found that truck. He's only running the HMMWV rims up front.
1,808
There is a member here that put 6 of them on his Dodge. He had a company he deals with make a spacer/adapter that is bolted onto the face of the inner wheel. The outer wheel (modified) bolts on facing the inner wheel. The adapters were hubcentric in design and he reported that it drove pretty nice. It can be done but I hate to see the cost of those adapters.
The following wrecker runs dualled 37s on the back and HMMWV rims on the front. Here's a short vid. With the wider truck axle you have you wouldn't need the inner spacer.
https://www.youtube.com/watch?v=ikaclBAXFFU
roveroverme
Banned
350
port saint lucie/ florida
The more I think about it , the less i feel like putting on HMMWV wheels , I think I'll go with M/T tires the way I had them on my old M1028A3. It's just less trouble- less cool than the HMMWV wheels, but less trouble.
Big CASE
Finger.TN
thank you all , i was thinking about this to?? .. I was thinking about running Michelin 325-85R-16 xml all the way around( X6 ) on a dully M1028A3 , with a 6" lift using the stock rim or the hmmwv rims .
I just know about the back spacing for the dully ?? what do yall think ? to big ,look weird
roveroverme
Banned
350
I'd probably go with a smaller size on the Dually wheels. just to keep some added distance between the two tires without having to have a spacer.
4,812
The 325's can't be used on the HMMWV rims. 16" vs 16.5".
Big CASE
Finger.TN
haa I got to thinking about that , just could not remember that they were 16.5.
spacers would be ok just don't what it looking like some kind of 4x4 mud bogger
