Has anyone turbocharged their CUCV?
Knightmare
Hiram, GA
I saw an article in this month's Diesel World, which discussed turbocharging the old Ford NA diesels, and our beloved 6.2.
On the 6.2, torque jumped from ~260 to 380 ft-lbs, and hp rose from ~140 to 200!!
That sounds like a pretty big difference to me, and I was wondering if anyone here had actually put a turbo kit of some kind on their rig.
I know these things aren't built to be fast, but you can't help but wonder what it's like with some extra juice under the hood.
kipman
15
Lancaster Ohio
I know of one member that installed a Banks kit on his. He is known as joeypusher on the site, pm him and he will help you.
1,172
I'm going with JATO rockets, myself. I don't need more top end, just takeoff power. Turbo's have limits....
steved454
brandon/ms
JATO is an acronym for Jet-fuel Assisted Take Off. It is a system for helping overloaded aircraft into the air by providing additional thrust in the form of small rockets.
hovenga67
Evansdale/IA
I turboed mine I used a 6.5 manifold. Holset turbo and tial external wastegate. Really woke it up, it can actually get out of its own way. I pull a 4000 pound trailer plus the load on it. does good now.
Brent
niferous
Houston, TX
Brent
So all you needed was a 6.5's manifold, a turbo, and an external westgate? How did you route the exhaust?
CA_CUCV
Santa Rosa, CA
I put an ATS kit on my 1008. The factory gears and big tires were killing me. Huge difference in power, it could use a little more bottom end, but I'm happy for now.
The kit uses a t3/t4 turbo that's matched to the engine, so it doesn't use a wastegate (I think the banks kit is the same just with a t3 exhaust) The boost tops out at 16 psi.
here's a picture of the kit:
niferous
Houston, TX
Does ATS make the kit anymore? I can't find it anywhere on their site. I'd be interested to know how much it costs compared to the Banks kit. Also from what I hear Banks won't be selling their version much longer.
hovenga67
Evansdale/IA
I used a 6.5 turbo crossover pipe, but had to modify it to use my 6.2 drivers side manifold. You could just use both 6.5 turbo manifolds and a stock crossover. I made my own down pipe and stuff. 3in down pipe and 4in. exhaust I had to cut a little bit of the floor so the down pipe would fit.
Brent
PackRatWrecker
Hays, KS
I am told, by the diesel guru I used to bend exhaust for, that a 6.2 will see more gains from headers, open exhaust, and an early 6.5 mechanical pump, than from a turbo.
That's just what I'm told.
1986Blazerk5
Brighton,MI
I really want a turbo on my M1009, alot of people have installed a turbo, alot of people use the 6.5 manifold and all the stuff can be had for around $800
SmokeyDod
Easley, SC
I have the Banks on my M1028 for 2 yrs and it make a huge difference in power. I bought a used one . The Banks won't give up 16 # boost. Mine is 8-10# range but when pulling a trailer with a load it makes an unbelieveable difference. The 6.2 will absolutely die on an upgrade if you are pulling 8000-12000 lb load but with the Banks it carries it well.
It just makes the truck much more of a pleasure to drive.
If you're putting 16# of boost on this engine with 22:1 comp. you might want to check for oil leaks and hope bottom end holds together.
btrapr
Monroe, NC
As far as i know the Military psitons had a .010" shorter wrist pion which lowered the compression to 20:1 THEY are not 21.3 like std 6.2 engines.
<DIV id=EBdescription><FONT size=2 face=Arial>Militray part information____
<SPAN class=ps39><FONT size=3><FONT face="Times New Roman">2815012465268
