- 137
- 13
- 18
- knoxville tn
my generator (MEP-831) ran poorly when i got it, after following the TM with no improvement i got the new governor from Kloppk (highly recommended) and when adjusted per the TM it would still not run quite right but much better (surging). a bit of tweeking and i found by setting the gap a bit to large (per the TM) the machine runs perfectly, starts great, takes load, rejects load, etc.. with one exception - it will not shut off on its own (when the off switch or E-stop is pushed) you have to hold the actuator arm against the magnet. When shutdown using just the off switch or E-stop the arm will pull to the magnet, start to shutdown, then let go, and the engine will continue to run (badly) smoking etc..
i then noticed some caulk on the pipe holding the magnet to the governor actuator arm and no wire lock on the magnet set screw as others indicated there should be (there is a wire lock on the engine throttle lever). so was thinking maybe some one in the past did (the forbidden per the TM) adjust the magnet. attached are some pictures. Could you guys compare mine to your machine's and see what you think? or am i just not adjusting my machine correctly.
I am not willing to touch the magnet till i can be fairly certain it has been tampered with and i'm just not dialing in my machine correctly, then if no other ideas from anyone, will try adjusting it.
first pic (left most) just shows how far "in" the magnet is in side its holder.
second shows the screw that holds the magnet in place (no lock wire or hole for one???
third shows the caulk/glue around the base of the magnet holder, normal???
fourth shows how i have it adjusted - this is as close as the magnet can pull the target (not correct per TM, but at this setting the gen runs great!) FYI - engine is off in pic i'm just pushing the target to the magnet
thanks for any input.
![20180228_174401.jpg 20180228_174401.jpg](https://www.steelsoldiers.com/data/attachments/495/495525-80fea138bf25b8cec71c34b0302ca8f3.jpg)
![20180228_174419.jpg 20180228_174419.jpg](https://www.steelsoldiers.com/data/attachments/495/495526-4eb0245023c2093c4772511c34e55f3f.jpg)
![20180228_174440.jpg 20180228_174440.jpg](https://www.steelsoldiers.com/data/attachments/495/495527-d872eb29f597cfad7f510d00fc062d5a.jpg)
![20180228_174505.jpg 20180228_174505.jpg](https://www.steelsoldiers.com/data/attachments/495/495528-4418e234f8151052fb3209e85dfcc71c.jpg)
