m1010freedom
- 0
- 6
- manhattan beach CA
So i was driving over this mountain pass yesterday on a forest service road and I noticed my radio started to turn on and off when it got bumpy. Thought it was a loose wire or something so i pulled over and looked under the dash. Nothing seemed loose.
I said screw it, ill figure it out later and kept going.
Then all of a sudden my brakes felt squishy. I pulled over and looked to see if i cracked a line anywhere. No fluid anywhere leaking.
But then i got a wiff of something burning.
So i turned the key off, took the key out and it took the engine 2 seconds to cut out after the key was out. Thought that was strange.
Got out and popped the hood. Right away I noticed ONE of the oil cooler lines was bubbling and smoking white smoke out of a ton of little pin holes almost like it was under pressure. The other one wasn't hot at all. I also noticed the hard lines from my brake booster reservoir were extremely hot as well and melted the plastic clip that holds the two lines together.
After it cooled off I went to turn it on again to see what it sounded like. And there was this awful clicking noise coming from the isolator switch between the two batteries. The stud on both the terminals was loose so it was actuating the switch on and off over and over again. So i tightened that back up and when to fire it up again for a second and it all seemed good besides the oil line dumping oil.
Overall I'm extremely confused. Im not sure if what happened had anything to do with that isolator going on and off while I was driving and somehow firing the glow plugs or something over and over again? (glow plug controller is gone and I use a switch in the cab)
Or if the oil cooler was clogged and it pressurized the line and melted it and it has nothing to do with the battery thing.
I ended up hiking 15 miles back into town to call a tow truck because there was no service up where I was. I finally got the truck back at our forest station and want to go through it this week.
Any help would be greatly appreciated. Im hoping its just a line i have to replace and the oil cooler. I just don't want to replace the line and cooler and it be something worse that caused it to happen in the first place.
