Hauling 915s
swbradley1
Modertator
1,628
Dayton, OH
Weight? Depending on trailer height you do have to remove the stacks.
wreckerman893
Possum Connoisseur
15,618
2,014
Can you get three 915s on a trailer if you stack the back end of two of them?
They weigh about 19K each.....that's almost 60K......you might get them on a 53 foot stepdeck by putting the front tires of one on the rear tires of another (daisy chain) but you will have a weight issue. Even if you are not over gross (80K in most states) you may be over axle weight (34K in most states). A law abiding trucker would not haul them due to fines and excess wear and tear on equipment.
plowboy
kansas
Thanks. The length is what I was concerned about. Actually only need 3 on one truck, axles are plentiful and gross weights are higher in the states involved. The 915 we have only weighs about 18450 if it's low on fuel and not covered in mud I think I can get enough misc off of the ones that have to be trippled and onto the other truck to make the gross a non issue....stacks, spare tires, and anything else that comes off can go on the other truck.
cottonfarmer
Marianna AR
Might you be hauling them from Hooks Tx? I bid on the three that had the recent rebuilds, looked at them the other day while picking up a 931. They were very clean, but went a little steep for me.
