After replacing my head gaskets i torqued them to 158 ft/lbs because thats what the instructions that came with the gasket said to do.
Later i found in a manual for the LDT that the torque is only 130 lbs. I think that maybe the 158 spec is for another engine that uses the same head gasket?
so should i just leave it torqued at 158 or should i loosen and retorque at 130?
