Head gasket leak??
texas30cal
87
Brenham Tx.
I think they may be new style, in one of the pics I see a tab sticking out, isn't that the indicator of the new ones? It was overhauled at TEAD in 92.
searls84
Las Cruces, NM
Looks to me that the oil originated from higher up.
My thoughts too. Like the exhaust ports at the manifold or maybe even valve covers. Check the valve cover bolts and exhaust/intake manifold bolts and nuts for tightness. If you have been letting it idle a lot recently, I would take it on a good drive to clear the exhaust of any build up or residue then degrease the motor and keep an eye on the suspected area(s).
The head gaskets with the tabs are the old style; known to weep a little.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
You can see the "tab" in the second(and third) pic. That old style head gasket was designed to seep according to the TM.
It can't hurt to check torque on the intake/exhaust manifolds too. I found mine not tight on my turbo truck.
texas30cal
87
Brenham Tx.
Well I climbed on top, definitely not valve covers. It's wet around where the elbow from the turbo meets the intake manifold, around the coupler from the turbo to the elbow too. Now I'm afraid of a runaway. Funny thing is that the gasket that seals the oil line to the turbo was leaking so I replaced, now the ferrule on the oil line at the turbo is seeping and it seems there is oil inside the intake, all this in a few days time. At this point I'm fairly certain the oil on the block is coming out between the intake manifold and the head.
gimpyrobb
27,785
749
Cincy Ohio
How long has it not been used? You just got it and started using it for what, 3 months? Things are gonna seep a little, I wouldn't worry about it.
texas30cal
87
Brenham Tx.
Got in October, put 1700 miles on it since, just degreased Saturday after replacing that oil line gasket. It's been dry up until this. Should there be oil inside the intake?
gimpyrobb
27,785
749
Cincy Ohio
None of my turbo vehicles have dry intakes, not sure if they should be!
Not sure what "oil line gasket" you are referring to.
texas30cal
87
Brenham Tx.
Where the oil feed line attaches to the top side it screws onto a fitting that is attached to the turbo by two 5/16" bolts and a gasket, I replaced that gasket, cleaned and inspected the line and ferrules. I believe it to be a D as my other trucks turbo has a MUCH more pronounced whistle.
texas30cal
87
Brenham Tx.
Neither can I, but I'm new to these and not a diesel expert by any means. I've always been a gas guy, always said alcohol is for drinking, and diesel was for washing parts ! It's just odd that within a week the flame heater injector started leaking externally, then the oil line, now out of the intake gaskets.
gimpyrobb
27,785
749
Cincy Ohio
Honestly, I wrench on mine as much or more than I drive it. Its a labor of love but gets to be a pita sometimes. I've learned not sweat the petty things(but like to pet the sweaty things).
rustystud
2,760
Woodinville, Washington
I totally agree with Chris here. At work we used the Federal Guideline for oil leaks . After driving the vehicle for at least 2 hours and letting it sit for 4 hours, if there isn't an 8" circle or larger of oil on the pavement under the vehicle then the leak is not considered a problem. So do you have a puddle of oil under your truck ?
texas30cal
87
Brenham Tx.
I do understand it's a old truck (my other vehicles are a 71 Cheyenne and a 79 corvette) and I do enjoy it, until I know a LOT more I just want to play it safe and avoid doing any damage due to a lack of fixing a problem.
texas30cal
87
Brenham Tx.
I was making a big puddle until I fixed the heater injector and the turbo oil line leak but only for a few days, I degreased and those are pretty much stopped but these leaks are brand new since sat. It's leaked all over the front diff, will degrease again and check every drive then report back.
