Kpswans
- 0
- 0
- Buffalo NY
My m1008 was leaking coolant out of the passenger rear headgasket. I just got done installing a felpro headgasket with arp studs I torque specked all the bolts and replaced all the gaskets that came with the rebuild kit.
after some cranking she fired right up and was running rough. I moved the injector pump to 1/16 past 0 advanced when I was in there since it was retarted a lot for some reason (driver side). I also turned up my pump.
I went back put the timing marks how they were and turned the pump back down through the top this time since I had the manifold on.
I have cracked each injector line multiple times in hopes of removing air if that's the cause. one injector causes the truck to stall very quickly even when slightly cracked not sure if that's relevant but figure the more info I can provide the better. its also smokeing black witch it never did before.
this is my daily and only car any help is greatly appreciated thanks everyone
