OK, in the last few weeks I have lost my horn and my fuel gauge (just reads hyper full), both at the same time. I also keep having a nagging problem with my passenger side headlight. It blew again this morning. I disassembled the headlight plug, checked it, cleaned it and reassembled. Looked over the wires (all seemed good) and checked to make sure the ground was GTG. hooked everything back up and when I turned on the switch, the light was dim, but not out. I then (finally) replaced the headlight switch and both lights were bright lights. WHOOPPPPEEEE!!! That is until this morning when that light went dim, then blew. What heck is going on???
Then, on top of that, over the last two weeks, my truck has been very hard to start. Fires off on the first turn of the key, but then dies. It takes about 4-5 5 second turns of the key to fire again. Once she catches, the idle surges for about 5 seconds, then smooths out. I have plenty of power once she starts and I have zero issues driving, passing or going up hills. It was only doing it in the morning, after sitting all night, but this afternoon when I got in it at work, she did the whole hard starting routine all over again. I did have a leak at the fuel filter and it was dripping on the ground. I did not get to it, but now there is no fuel leak evident any more. I am wondering if fuel is draining back into the tank as she as sitting for a period of time.
Just looking for some ideas. I would like to fix it before I travel in a few weeks on work related business.
Thanks !
Thanks !
