headlight / drivinglight problem
kamakee
melbourne florida
my headlights/driving lights wont come on does anyone know the location of the headlight relay what does it look like and is it readily available thanks a million ...tony
11Echo
92
CT W. R.
The headlight switch should have an auto-reset circuit breaker built into it. Since you mentioned elsewhere that your horn/turn signals/brake lights work, I'll assume your toggle switch for the service lights is in the on position. It seems the ground wire connections for the forward lamp harness are failing. Check your black wire grounds.
It might help if the moderators move this thread to the CUCV Forum.
