Headlight Questions
CSX4350
Seguin Texas
Hello listers, a newbie here with a couple of quick questions. i recently bought a 1968 M35A2 that had been "fully restored". We won't go into that....
Anyway, among other things the drivers side headlight is out. I went to remove it and found that I have no idea what I'm looking at. I've never seen headlight connectors like this. I understand that the wires are permanently affixed to the light, and I assume that they somehow unplug from the back of the headlight bucket. This is where I start to get lost, I don't understand how they unplug and don't want to break anything.
Second, looking into the left (drivers) side headlight bucket, there are electrical connectors at 10:00, 2:00 and 6:00. I assume one is low beam, one high beam and one is the ground, but which wire is which? I can see the wire at 10:00 has been kinked and is a bit frayed behind the bucket, just wondering if this is the low beam and could possibly be the problem.
I have searched quite a few different ways but couldn't find any information on these questions. I did see a thread on converting to H4's, and may just do that, but still would like this information.
TIA
John
Westech
CPL
6,104
210
cow farts, Wisconsin
ok first of all get the TM (technical manual) and START READING!!
you can get the lights off eBay or any of the military parts suppliers. The wires have a little crimp band with a number on it. That number matches with the number it plugs in to. If there rubber they just pull off... if there metal a 1/4 turn and it pulls off.. like a auto light bulb.
CSX4350
Seguin Texas
Thanks, I thought they would just pull off but as I said I like to check things out before I tear something up. It's cheaper that way... A quick voltage check showed me which was which and the wire I was worried about is the ground and is fine.
I have three different TM's, but couldn't find this information in any of them. Then again, they all read like bad Japanese stereo instructions.
runk
66
Houston, TX
It is reasonably common to see the headlight wires without the nice rubber connectors on the wires. Mine had cheap plastic crimp splices (3), twisted bare wires (1), and the grounds to nearby bolts. There is a good wiring schematic posted in one of the threads on this site, make sure to read through the thread to find some corrections.
CSX4350
Seguin Texas
Wow, thanks for that, I never thought about the headlight schematic. Once I found it I saw that whoever installed the headlight got at least some of the connections wrong. If I'm reading the schematic right 17 is the high beam?
Thanks again.
earnie
seattle ,washington,usa
all of the connectors and related bits for the wiring can be sourced from saturn truck parts, to include the cool little wire tags, all ya have to do is stamp them with your numbers and good to go
while on the headlight subject,if i can borrow your thread for 1 question , where can i find the yellow 24 volt headlights for my deuce
badgmc56
Southington Ct.
earnie, the yellow headlights are on e-bay from time to time. Be ready to pay for them cause they are not cheap. Wagner has a number on them which I don't remember at the moment but I don't think they make them anymore. I'll see if I can get the number for you.
1,191
Send a PM to ZiggyO, he had some yellow headlights, a while ago.
#17 is highbeam
