headlight switch replacement
galeo7171
Cumming, Ga
I'm trying to track down why my tail lights or running lights aren't working. Changed all bulbs and fuses and check all the wiring and connections, everything seems ok. I'm thinking its my headlight switch because if I pull the hazard light switch, all the tail lights and running lights work. Am I on the right track? Any advice on changing out the switch (anyone know part numbers?)
galeo7171
Cumming, Ga
I do need to take a look at my turn signal stuff. For some reason I can turn the turn signals on even when the truck is turned off and the ignition key is removed, I have no idea where to start looking to fix that.
salt6
B'ville, OK
Go to NAPA they or any of the big box part stores can fix you up. I've got the same problem and a switch swap didn't fix it. Good luck.
mudman
10
Carson City, NV
My trun signals work with the power off also. I'm just saying that your light problem could be partly due to a faulty signal switch.
