Headlights acting wacky, need info
123pv
GreenwellSprings/Louisiana
I am a new member here. 2 weeks ago I bought, a k30 cucv fo 5 thousand dollars it was running great. tonight I was leaving a restaurant. when I started up my diesel the head lights came on.
after driving 2-3 miles the lights. turned off. I did not touch the right black out switch. a cop pulled me over to tell me to turn on my lights. I pulled the right switch out then flipped it up still no head
lights. my volt meter was in the red. is my alternator not charging. or do I have bad batteries? is there a way I can pull out that black light crap. turn it into a civilian k30 truck without that military
lights crap. is there some fuse, or relay I can remove? ( do I need new alternators?
porkysplace
1,493
mid- michigan
I would be happy to I have family there.
also I would like to tell every body hello. I am a new member here. 2 weeks ago I bought, a k30 cucv fo 5 thousand dollars it was running great. tonite I was leaving a restaurant. when I started up my diesel the head lights came on. after driving 2-3 miles the lights. turned off. I did not touch the right black out switch. a cop pulled me over to tell me to turn on my lights. I pulled the right switch out then flipped it up still no head lights. my volt meter was in the red. is my alternator not charging. or do I have bad batteries? is there a way I can pull out that black light crap. turn it into a civilian k30 truck without that military lights crap. is there some fuse, or relay I can remove? ( do I need new alternators?
Welcome to Steelsoldiers .
You will get more help posting in the correct forum for your truck .
CUCV
M1008, M1009, M1010, M1028, etc....
For your headlight problems read these threads ;
HEADLIGHTS
CUCV Headlight Circuit
http://www.steelsoldiers.com/showthr...dlight-Circuit
CUCV Melting Headlight Fuse and Horn Circuit fix
http://www.steelsoldiers.com/showthr...t-fuse-melting
LMC Headlight Wiring Harness upgrade
http://www.steelsoldiers.com/showthr...ht-circuit-mod
They are found in the stickies in the CUCV forum under
CUCV Helpful Threads
ALTERNATOR
GEN1 and GEN2 Exciter circuit troubleshooting
http://www.steelsoldiers.com/showthr...roubleshooting
CUCV Isolated Ground Theory of Operation
http://www.steelsoldiers.com/showthr...y-of-Operation
CUCV Alternator-symptoms-diagnosis-and-fix
http://www.steelsoldiers.com/showthr...gnosis-and-fix
CUCV Alternator Rebuild - illustrated
http://www.steelsoldiers.com/showthr...rnator-Rebuild
http://www.steelsoldiers.com/showthr...build-Question
Convert a Civvy Alternator to an Isolated Ground if you busted your case
http://www.steelsoldiers.com/showthr...und-Alternator
Alternator Rebuild Kits
http://www.steelsoldiers.com/showthr...mp-repair-kits
No need to chop up your wiring system if you take the time to learn how it works and what maintenance is required on a 30+ year old truck. The general rule for owning a CUCV is if it is rubber place it , if it is electrical clean it ( meaning cleaning all plugin connections and grounds ).
1,178
The OP hasn't been back since posting this thread 7 years ago.
123pv
headlights almost got me killedshutting off compleatly while driving down windy city
also I would like to tell every body hello. I am a new member here. 2 weeks ago I bought, a k30 cucv fo 5 thousand dollars it was running great. tonite I was leaving a restaurant. when I started up my diesel on a cold night the head lightsand taillights came on. after driving 2-3 miles the lights. turned off. I did not touch the right black out switchwhile driving. a cop pulled me over to tell me to turn on my lights. I pulled the right switch out then flipped it up still no head lights. my volt meter was in the red. is my alternator not charging. or do I have bad batteries? is there a way I can pull out that black light crap. turn it into a civilian k30 truck without that military lights crap. is there some fuse, or relay I can remove? ( do I need new alternators?) I left it in a parking lot all night alone.
porkysplace
1,493
mid- michigan
You already have posted this in another thread that Doghead split off into it's own thread , you should continue your posts on this issue in that thread.
Have you read any of the links I posted in that thread ?
Have you done any basic tests of your alternators ?
Have you cleaned any grounds or connections ?
1,178
Merged your threads, do not post duplicate threads/posts. Next time you will get an infraction point.
Reread the rules please, and try to follow them.
cucvrus
10,427
Jonestown Pennsylvania
Welcome to the hobby. I would look under the dash on the left side at the fuse block. I am sure you have a bad 30 amp fuse on the right side of the fuse box midway up. It is a common problem. It can be fixed easily without any real difficulty. Go under there and you will see the slightly melted fuse. the heat has unsprung/weakened the tension on the fuse and created a hot spot in the circuit. I used LED headlamps and tail lamps to relieve some of the amp draw on the circuit. That has worked well on a few trucks just by changing the headlamps to LED. There are other options. Some include adding another wiring harness for the headlamps. I have several CUCV's and never done that. IMHO it can be fixed by cleaning all the grounds and light sockets and getting the fuse to fuse block connection tight. Check that fuse out and do some cleaning and report back with your findings. I will do my best to assist you in getting the CUCV in top notch operating condition. Good Luck. Once again welcome to the CUCV hobby. This is a very easy fix and will require a minimum of time and tools. That is provided no one has hacked into the lighting electrical system. At this point I will assume it is NOT hacked up and is just the same common issue. I pictured the Truck lite LED headlamps above. Great upgrade and eliminated a hot fuse box on several of my CUCV's. NOT cheap. But I am not a fix it on the cheap type of guy.
