I am trying to figure out why my headlights are not working on my M1009. All the regular service lights work like normal. The blackout switch on the right it up. I have checked all the fuses on the panel under the dash and they are ok. I have voltage at the 30amp fuse. No voltage to the headlights. I suspect that the civilian type pull headlight switch is bad. Is there any other fuses or relays that are headlight specific that need to be checked? Any idea how to check that pull switch? The headlights worked for about a minute when I first got it home from the base.
