Headlights not working
dstang97
30
Clover, SC
Got a new to me 929. All exterior lights work except for the headlights. No high beam or low beam. No voltage at any of the prongs. Weird thing is when I set my meter to resistance it’s ringing out between ground and I believe pin #17 at the headlight. Anyone have this problem? Maybe bad headlight switch or high beam switch grounding out?
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
Check that you have power to the dimmer switch as well. No power at the harness plug into the hood. More than likely it's a main switch
