Heater fresh air tube
juanprado
3,204
Metairie/La (N'awlins)
That is common duct hose. Measure the Id which should be the same both ends and length.
Napa will have it in gates and other hd parts stores should have it. Oreilly can probably order in.
Guyfang
27,298
Burgkunstadt, Germany
Tech data for hose.
CROSS-SECTIONAL SHAPE STYLEROUND
INSIDE DIAMETER4.000 INCHES NOMINAL FIRST END
MINIMUM INSIDE BENDING RADIUS1.125 INCHES
CONNECTION TYPEPLAIN BOTH ENDS
FEATURES PROVIDEDOZONE RESISTANT
MAXIMUM OPERATING PRESSURE5.0 POUNDS PER SQUARE INCH
EXTERNAL OPERATING PRESSURE5.0 POUNDS PER SQUARE INCH
MATERIALFIBERGLASS 1ST PLY AND RUBBER CHLOROPRENE CLASS CR 1ST PLY
MATERIALFIBERGLASS 2ND PLY AND RUBBER CHLOROPRENE CLASS CR 2ND PLY
MATERIALSTEEL REINFORCING WIRE
STYLE DESIGNATORHELICALLY WOUND CONTINOUS WIRE SUPPORTED
TEST DATA DOCUMENT19207-8711053 THRU 8711056 DRAWING (THIS IS THE BASIC GOVERNING DRAWING, SUCH AS A CONTRACTOR DRAWING, ORIGINAL EQUIPMENT MANUFACTURER DRAWING, ETC.; EXCLUDES ANY SPECIFICATION, STANDARD OR OTHER DOCUMENT THAT MAY BE REFERENCED IN A BASIC GOVERNING DRAWING)
SPECIFICATION/STANDARD DATA81349-MIL-H-62028 GOVERNMENT SPECIFICATION
NONDEFINITIVE SPEC/STD DATA1 CLASS AND 1 TYPE
