Heater Hookup?
Knottofs
White Level, NC
I just got a 24-volt heater for my truck. Dose anyone have a diagram / Know where the hose connects up to the engine, and then to the heater, and from the heater back to the motor. I see a plug on the back of the water pump, but I can’t find another plug anywhere. Any info would be much appreciated. Thanks, Nate
steelandcanvas
85
Southwestern Idaho
Same here, but I would like a copy of the oringinal installation directions.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
RE: Re: Heater Hookup?
Well, if its the 230 Tornado, it will be on the passenger side of the motor, between the last 2 cylinders.(near firewall)
bcowanwheels
KINGSPORT, TN.
I,LL look my m715 over tomarrow and post exactly where to hook the hot and cold ( return lines up for ya ) i,d suggest installing a cut off valve for the hot water out of the engine for cooler summer use. seems like it was on the passenger side of the head near the rear for hot out and the water pump for cold return line. been a while....
bob
bullgear
Locust, NC
That's correct... comes out of the side of the head on the right near the back and returns to the water pump. They originally used a long 90deg pipe (pointing forward) coming out of the head to clear the firewall and heater box.
