Kharville
- 0
- 6
- Clinton LA
Are you working on a HMMWV or a M35A2 , you posted a article for the HMMWV but thread is in the deuce forumI am trying to validate my heater hoses against the PS article below. Is my top hose where it should be? I can't really tell from the quality of the picture.
View attachment 711896View attachment 711895
The article I posted is the same one you mentioned. "Multifuel 2.5 ton". It is for Deuce. Where did you see HMMWV?Are you working on a HMMWV or a M35A2 , you posted a article for the HMMWV but thread is in the deuce forum
and no mention of what truck your trying to install it on .
If your trying to install on a deuce post #9 of this thread has the correct article.
M35 hot water heater
Edit; spelling![]()
Can't really tell in your pic what you have, but it don't look right.I am trying to validate my heater hoses against the PS article below. Is my top hose where it should be? I can't really tell from the quality of the picture.
I am confused. The one on the right is my Deuce.The article on the right has a pic of humvee... but the article is correct. Tm will have proper routing of hoses as well.
Validate your heater hoses hookups by searching Steel Soldiers.
Also search for coolant filter setup with and without a cab heater.
Anyhow, here is some stuff to add to the confusion.
What not to do with or without a filter.
and pictures of what has been done with coolant filters, with and without cab heaters.
View attachment 711901View attachment 711902View attachment 711903View attachment 711904View attachment 711905View attachment 711906
View attachment 711900View attachment 711909View attachment 711908View attachment 711907View attachment 711910
View attachment 711915View attachment 711914View attachment 711913View attachment 711912View attachment 711911View attachment 711907View attachment 711916
Ain't pictures wonderful?
rustystud post the link to all your heater setup pictures or post them here,
You always get honorable mention for your stuff.
Help add to the being in the land of crystal clarity a bit more.
