Hello folks! New to me 1010. Injector Pump replacement issues!
tod0987
NC
Hi guys. I'm a long time lurker back to 2011 from looking for a 715 years ago and then working on a buddy's m998 and grabbing the TMs for it.
I recently purchased an 84 M1010 with 4,300 miles that was converted into a camper. It was a USN 1010 and then it spent a few years as a FD truck near St. Louis for a FD to use at football games. The previous owner bought it and then fell out of touch with it. It has sat for over a year and no longer runs.
I've downloaded and been through all the TMs and I'm getting better at using them, mainly the 34p and 20p so I have exhausted some of those tips. I don't like to just hop on and ask simple questions without exausting my search abilities.
Previous to pulling the Injector pump (where I'm at now) I did replace the fuel, filter, have 8psi out of the mechanical pump, on/off selinoid, GP board is good, GPs were replaced with 60gs and they are heating up. No fuel was coming out of the IP so I pulled it and sent it to a shop in Wisconsin to be rebuilt. He called today and told me that the rotor is no good (likely the previous owner tried biodiesel and it ate away the metal while sitting) and I need to find a core to pull the rotor out of to rebuild mine.
My question is, is that the original 2829-4269 pump is supposedly setup to handle higher elevations with less oxygen, are there other models that have the same power? The 4269 is a hen's tooth. I believe the 1010 made more power than stock cucvs. I'm trying to figure out my options of find a core (to get the rotor) and have him rebuild mine to a new spec for where I'm at (sea level in NC) or to replace it with a new and have to eat the core charge.
Any help or recommendations is greatly appreciated, Thanks,
Tod
The previous owner had a 4" lift and 35" tires.
He had it lined with sheep's wool insulation and cedar tongue and groove which stuck badly like an unkept barn so I've gutted it. The truck lost all of its ambulance interior prior to my acquisition.
Barrman
1,781
Giddings, Texas
I have never read that the M1010 had more power than the rest of the CUCV vehicles before. Nothing is mentioned in the manuals about that either. GM had 2 versions of the 6.2 back then. The EGR equipped low power version and the non EGR J code version in the CUCV trucks. The intake manifold was the only difference. Both had the same basic engine.
The high altitude difference you mentioned is more a matter of adjustable fuel rate and timing. There was an artic “kit” that had supposedly better consumable parts inside the IP. That special kit became the standard for all the IP’s at least 30 years ago.
You just want any DB2829 IP to use as a core. Here is a video I did about the IP identification and the numbers:
tod0987
NC
Thanks I'll check it out. I'll try and find the mention of turned up IP to handle the weight of the ambulance body.
tod0987
NC
Tim I just had time to watch the video and realized I sub'd to your channel awhile back and watched many of your videos while trying to attempt to start this truck wrt priming and starting and replacing the solenoid etc. I love the 715 with the 6.2. Thanks for putting them together!
chevymike
463
San Diego, CA
Nope, there was no difference in the engines/IP/Tuning of an M1010 and any other CUCV's. They are all interchangeable, outside of the alternator and A/C brackets. That said, you can adjust the IP timing (the marks on the top of the pump, near where it mounts to the engine cover) which can add a slight amount of power more but at the risk of pistons running hotter.
tod0987
NC
Thanks for the input. I'm starting to feel better about using one with different numbers still a DB2829 but with different following numbers.
ballencd
78
Columbus, NC
Hey Mike, Does this look right?
I could not tell if the heavy mark is factory and its way off or if the light mark is factory and it could be a bit more to the drivers side? Any ideas? Thanks Charlie
Barrman
1,781
Giddings, Texas
I think the deeper mark is the factory “Center” mark. Where you have it should be pretty close to max advance without some way of checking your actual timing. . However, just a tiny movement in either direction from where you are can have a huge seat of the pant feel difference.
ballencd
78
Columbus, NC
Thanks for the fast response. Pictures I've seen in the past were closer to the factory then this one so I will attempt a slight move closer and see if that feels different. It seems to be running pretty well after the tank, lift pump, injection pump and sending unit replacement. Next up is transmission mounts and flush the radiator. Thanks again.
Finnegan1008
164
Connecticut
Thanks for the video! What did you use to film it? It’s high def
chevymike
463
San Diego, CA
Yeah, the deep mark is 0 timing. Moving one way or the other of that mark advances or retards the pump timing. I think most pics I have seen show the secondary mark advanced to the driver side. I believe the factory makes the second mark across the mount and pump once they get it set, so it can easily be put back to factory timing, if pump is ever removed.
