Hello from Minnesota
19,605
Just picked up my first diesel and my first CUCV 1984 m1009. I'm both afraid and excited for the journey!View attachment 931889
Welcome to the Outfit!
Don't hesitate to download the TM's (Technical Manuals) for your "New To You" truck. Post us some more pics as well. Especially under the hood so we can help you solve problems if your factory wiring has been hacked up.
Again, welcome to the group!
Sack
Minnesota
Thank you man ! I found the TMs started reading last night. I’ll definitely be needing them.
19,605
Good Deal! Yessir, they are dry reading but they will help you a lot if you need info...
Looks like somebody did a bypass on the glowplugs. That can be fixed or be just fine. Only need to push that button for maybe 10 seconds when you go to start her up. The wiring under the dash is a bit of a mess, and out under the hood looks pretty good. I suggest taking the #10 red wire off the "bus bar" (second pic, behind the master cylinder) off and cleaning those connections. Polish them up so they look like new, then apply a little anti-oxidant paste. Anywhere else that it looks like that - so the same.
Sack
Minnesota
Never even heard of anti-oxidant paste, already learning! I'll pick some up, thanks for that tip.
