Hello from Mississippi
Cal3bCart3r
MS
Whats up guys. I have a 84 m1008 with 37,000 miles from govliq auction. Got it for a really good deal too. Luckily to me, it only bad a bad starter and leaky valve cover gasket. But all is changed and when i got her home, immeditely threw on a set of 37s with no fender trimming.
Cal3bCart3r
MS
Having trouble with the rear brake lights and rear flashers not working at the moment. All other lights work fine up front and inside.
Also getting the death wobble pretty bad, which i know its from the 37s, wondering if i just need new steering stabilizer or if ball joints are possibly wore out. (It drove fine with stocks and a few months with the 37s then started doing the death wobble) where would be a good start on The front end?
FloridaAKM
392
Gainesville, Florida
Welcome from Florida, good looking truck. The experts will be along in a short while to answer your questions. I would start with a new steering stabilizer before changing out any ball joints, unless you have tested them & they show they are bad.
german m1008
1,317
Rhein-Main Area, Germany
Welcome from Germany.....nice truck.
Search " Death wobble " on the Site.....i'm sure you will find the answer to your problems.
And BTW Download the CUCV TM's......
1,807
Welcome aboard. You are likely looking at kingpin bushings and springs to correct the death wobble. Tail light issues eh? A good guess would be socket issues. Replacements are cheap and plentiful.
Al Capone
Pearl river la
What type of tires are u running ? Old bias ply mud tires will give u death wobble . I had s friend get killed with a brand new set of 38 inch tall tires he installed on his jeep and on his first test drive . I run steel belted radial super swampers and running same set of them I bought bed about 12 years ago on my jeep . Someone up around Hattiesburg has two sets of those hummer tires and wheels one set like new for $400 for all of them
Cal3bCart3r
MS
Thanks guys ill check out the TMs and gonna try to trace down my light situation today... Ive been lurking a little while on this site but decided to do my first post
AZK9
PRC, AZ
Welcome from Arizona and... welcome to posting! It really adds a positive dimension to the whole MV experience! [thumbzup]
