Help... Broke down with M101a2 in Easton, PA
Ratch
Chester County, PA
Well, I let my main m101 sit all winter untouched, then grabbed I to head to NY for the day, and the bearing grenaded on I78.
Anyone know the civilian equivalent part number for the wheel bearing? Surprisingly, I couldn't find it on SS.
I'm in a Walmart lot right now, but want to run over to Napa for a new one. I'm too far from home and too far from anyone to leave it and come back another day.
1,125
Since the M101 and M101A1 use the same hubs as the M37 and M37B1, you can utilize the parts cross reference page on my website, or you could contact any of the M37 parts dealers and order from them...
The parts cross reference page on my website for the M37 is located at
http://www.garbee.net/~cabell/PartsCross.PDF
To save you the effort of pulling up the page and looking at the first six lines, here's the info... :smile:
Bearing-Wheel, large: Timken 28682
Bearing-Wheel, small: Timken 2984
Race-Wheel, large: Timken 28622
Race-Wheel, small: Timken 2924
Flange Gastket: NAPA J26288
Seal, Inner Hub Oil: NAPA 49426, CR28116
These numbers also work for a later Dodge Power Wagon (the WM300's and the '50 B2 for instance) in case you need to tell your parts counter a civilian application...
Good luck.
From this thread: http://www.steelsoldiers.com/showthread.php?27357-M101A1-Parts#post646947
1,125
I gotta' walk out the door (I'm at work) but I think the thread I linked you has some discussion and links about A1/A2/A3.
1,172
Outer bearing is a Timken 12313045 Inner bearing is a Timken 12313046
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
I have a M101a2 and two M101a3's On the ones I have the bearing, seals brake drums and brakes are the same. I do not know about the M116 series but would think that all the 8 lug trailers were the same.
Here are the Bearing Numbers.
LARGE BEARING/RACE
Inner Bearing 25580
Inner Race 25520
SMALL BEARING/RACE
Outer Bearing 2585
Outer Race 2520
GREASE SEAL
10-36 (double Lip)
The bearing and race numbers are for Timken. They are more expensive. I used china bearings in mine.
Here is a good source for parts. http://www.etrailer.com/
Here are the Bearing and Races:
http://www.etrailer.com/p-25580.html
http://www.etrailer.com/p-25520.html
http://www.etrailer.com/p-2585.html
http://www.etrailer.com/p-2520.html
Seals:
http://www.etrailer.com/p-RG06-070.html
Brake assembly MINUS the parking brake Lever and Strut:
http://www.etrailer.com/p-23510.html Right side
http://www.etrailer.com/p-23510.html Left side
Brake Shoes:
http://www.etrailer.com/p-BP04-160/12-x-2-Hydraulic-Trailer-Brake-Shoe-and-Lining-One-Wheel.html
Now if I can find these at a Parts Store that are remanufactured they would be alot cheaper.
1,172
Outer bearing 3110-01-165-4860 Features
MRC
Parameter
Characteristics
ABMK
Overall Width
1.0000 inches nominal
ABXV
Bore Diameter
1.3125 inches nominal
ADGA
Overall Outside Diameter
2.6150 inches nominal
AGWU
Backface Corner Radius
0.1300 inches nominal
AGWV
Standout Width
0.1875 inches nominal
AGWW
Cone Corner Radius
0.1400 inches nominal
AGWX
Cone Width
0.9983 inches nominal
AGWY
Cup Width
0.8125 inches nominal
MATT
Material
Steel overall
STYL
Style Designator
Straight bore, normal angle
3110-01-165-4860 Manufacturing Part Numbers (SKUs)
MFG SKU
CAGE
STATUS
ISC
RNVC
RNCC
SADC
DAC
HCC
RNAAC
12313045
19207
A
AZ
12313045
43991
A
ZZ
12313045
60038
A
ZZ
2520-2585
60038
A
AZ
2520-2585
60038
A
AZ
3110-01-165-4860 Manufacturer
MFG SKU
CAGE
Manufacturer
Type
Role
12313045
43991
FAG Bearings Corporation
A
A
12313045
60038
The Timken Corporation
A
A
2520-2585
60038
A
A
12313045
19207
U S Army Tank Automotive Command
A
A
1,172
inner bearing 3110-00-100-5305 Features
MRC
Parameter
Characteristics
ABMK
Overall Width
0.9375 inches nominal
ABXV
Bore Diameter
1.6875 inches nominal
ADGA
3.2650 inches nominal
AGWU
0.0310 inches nominal
AGWV
Standout Width
AGWW
Cone Corner Radius
0.0900 inches nominal
AGWX
Cone Width
AGWY
Cup Width
0.7500 inches nominal
AGYF
Retainer Fabrication Method
Pressed
CTFZ
Standard Tolerance Designation
Afbma class 2
MATT
Material
Steel overall
STYL
Style Designator
3110-00-100-5305 Manufacturing Part Numbers (SKUs)
MFG SKU
CAGE
STATUS
ISC
RNVC
RNCC
SADC
DAC
HCC
RNAAC
12313046
19207
A
AZ
12313046
60038
A
ZZ
154940
15434
A
KZ
25520-25578
52676
A
ZZ
25520-25578
60038
A
HD
25578-25520
60038
A
X
XX
25580-25520
60038
A
ZZ
3110-00-100-5305 Manufacturer
1,172
Bearing info is listed in the one sticky for the trailer forum. I just edited the title to include the word bearing.
1,172
So, how did it go?
