Neut
- 0
- 0
- Pendleton, Indiana
I just recently bought a 71 deuce mutifuel. My voltage regulator was overcharging my batteries. I got a good generator and was told to hook up the signal wire to a oil pressure switch. the thinking is that the on/off switch contacts are out of spec and is hard on the generator. I was told to hook up the oil pressure switch to the block and wire one termnal to the battery and the other to the R wire on the generator. The pressure switch turns on at 15 PSI. once the engine starts and the oil pressure goes above 15 psi and the generator starts. I need suggestions where to put the switch. Or if this is just crazy.
