- 5,580
- 345
- 83
- DESOTO, KANSAS
Just checking to make sure I have gotten this right. I got some G20's that were supposed to be on M818 friendly rims, they aren't. Turns out they are mounted on the older PLS Trailer 3 piece wheels and are not like any lock ring wheel I have broke down in the past. So before I screw up and damage me or the rims I want to make sure I have it right.
1 one remove air & valve core from tire
2 use lever bar to push sidewall down from slide ring
3 start at one end of lock ring and pry up out of slide ring & remove
4 remove O ring
5 remove slide ring
6 flip over and remove wheel from tire
In the picture below from wehring's post the big part = wheel, 2nd biggest = slide ring. 3rd = lock ring, O ring= O ring
And if anybody has a use for the wheels let me know before the go to the scrap pile.
4 remove O ring
5 remove slide ring
