Help diagnosing failure to crank or stay running
Miscexpense
Alabama
Need help guys. My 1043 stalled out while sitting at a red light yesterday. I got it to crank back after trying for a few minutes. Today I got it to crank in a garage and it stayed running for about 30 seconds and did the same thing. Fuel is at 1/2 tank. So I went looking for electrical and found a post on one of the batteries was partially melted. Bad ground?? Or has the power issue fried the pcb?
NDT
6,280
Camp Wood/LC, TX
You will need to narrow down electrical or fuel issue. Put a voltmeter on the solenoid power lead at the injection pump to eliminate that cause. Then chase fuel issues.
Dock Rocker
72
Jackson ms
My guess is it is fuel related.
Check your fuel filter. Have you done your PM’s on your fuel system?
Check your lift pump and make sure it’s working and getting fuel from the tank to the injection pump.
Make sure that the inlet in the tank isn’t clogged with the sock from inside the tank or other trash. That will make for intermittent fuel problems.
If those check out then you need to look for air leaks In your fuel lines.
Last your IP may be taking a dump.
papakb
1,184
San Jose, Ca
If your fuel system is operating normally the IP can draw enough fuel to help a failing mechanical pump until it gives up the ghost entirely. Disconnect the #54 wire from the top of the IP so the truck won't try to start and crank it with the fuel petcock open and see what kind of flow you have. If it just dribbles out the pump on the engine is probably bad. It's a standard GM pump and you shouldn't pay more than $20 for a replacement. When you replace the fuel pump drop the mounting plate too and make sure the pump actuator pin isn't bent. Here's a link to a posting about the job:
https://www.steelsoldiers.com/showthread.php?182645-Part-for-88-humvee-fuel-pump&highlight=fuel+pump
Retiredwarhorses
4,122
Brentwood, Calif
Many many of these A2’s have bad fuel from GP, algae in the fuel tank, clogged fuel filters and now bad injection pumps due to the all of these previous items noted. The worst offenders are the Georgia trucks, haven’t. Seen it as bad on the Yermo calif trucks. I R&R the entire fuel system when they come into the shop.
start by pulling you fuel filter.
