Hasdrubal
- 4
- 0
- Vancouver BC
Officially stuck..at least I'm at home. Decided to open a new thread for this problem, hopefully I can get some ideas from you guys. Had to replace the fuel lift pump yesterday, at the same time I swapped in a new filter assembly. went to bleed the system today with an air compressor @5psi. Got no joy so decided to do it the standard way by cranking. Pulled the pink wire from the IP, went to turn her over.
Instead of cranking I got an unusual other sound and noticed a puff of smoke from my rear battery negative post. Didn't have it turned on for more than a second. A small part of the battery post has melted. I have done no electrical work except for the connections to the new filter assembly. I believe it shorted as I went to start and not when it was power on. The truck has run withought problems before this.
After triple checking everything I could think of before the sun went down and it drops to -8. I found the following; 1) On the red cable that goes to the starter near the lift pump where it drops over the frame rail edge, it appears a small groove has worn into the jacket where it has been rubbing. Couldn't tell if it was deep enough to get to the core. but I wrapped it in electrical tape. 2) On the negative bus bar, the innermost terminal was slightly loose, tightened it. Everything else looks good.
Am I correct in assuming this short was starter circuit associated? I haven't tried to crank it again out of sheer apprehension. I can only hope it was the starter cable rubbing on the frame rail. Is there any way I can test this withought cranking?
