Help finding g749 tie rod ends.
JerseyHick
Cherry Hill, NJ
Just wondering if any of you guys have a source for tie rod ends. One of mine is toast.
Checked Alfa Heavens site, no luck.
Any ideas?
Thanks, Ray.
vtdeucedriver
Vermont
Any ideas?
Thanks, Ray.
Did you call them???? Its always been my interest to call to see as they might not have enough of them worth listing. Never hurts to call and ask.
m1010plowboy
2,698
Edmonton, Canada
G749 Tie Rod ends.
Welcome home!
I saw new ones in a trailer up north. I need to make a trip before........well before it stops being warm.
I don't recall the difference left to right, something about thread, but I'll see what is there and if you don't find a local source I'll trade one for......19 more pictures of your build and finished truck.:-D
Good to see you're still around with the crew cab!
JerseyHick
Cherry Hill, NJ
Thanks VTD. Good idea, I'll call Alfa Monday.
And yes Plowboy I'm still around. Been a little busy on a new 749 project. Think a few of you guys will like it. I hope to have it completed in two weeks. I'll post pics when it's done.
hendersond
29
Galesville, WI
I may be looking at a pair while I type! what one do you need?
Do you need anything else?
I'll PM you my number
PS. I dug my 4 door cab out of the shed last week and started working on it again. At least it is all green now. I got all fired up when I came across a couple chunks of frame rail. I cannot decide if I should slide the axles back and remount them or cut the frame. If I recall correctly, that second cab only adds 39".
JerseyHick
Cherry Hill, NJ
Thanks Henderson. I'll check what thread I need and I'll let you know.
As for your quad cab. Do I understand correctly, your gonna cut your frame. Add a section, lengthening your wheelbase. Then you could use a full bed, not a shortened one like mine... THAT, would be a beast!!
vtdeucedriver
Vermont
Is there a thread here on yours??? I like it. That says a lot as Im a purist.
