help for users with firewalls.. ports pls..
OPCOM
27
Dallas, Texas
I have restricted many ports on the home router due to annoyances from the internet. Unfortunately GL seems to use one I am not familiar with for the LOGIN function.
What port is necessary to be open on the user's computer to have success when clicking on LOGIN ? It is between 111 and 8079. I sort of don't want to try all of them..
Rattlewagon
SW PA
if its https it should be port 443. I would try that one first before turning your FW into a sieve. I really can't think it would be anything else...
but it is GL after all..
maybe someone a little smarter than I can chime in...
dan
OPCOM
27
Dallas, Texas
That is it.. 443 must be permitted. Thanks.
There is something, actually many thousands of somethings, out there that keep trying port 36177 here. I think it's bad juju. Too bad there is no way to IP-elecro-bomb them back to 'dos on a diskette'.
Look at this mess, only 12 minutes worth:
Sat, 09/05/2009 01:26:43 - TCP connection dropped - Source:213.17.52.64, 50296, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:27:07 - TCP connection dropped - Source:83.145.243.65, 50656, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:27:11 - TCP connection dropped - Source:98.22.242.41, 60557, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:27:47 - TCP connection dropped - Source:69.153.138.77, 4444, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:27:51 - UDP packet dropped - Source:217.120.167.106, 40001, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious UDP Data'
Sat, 09/05/2009 01:28:11 - UDP packet dropped - Source:77.164.158.66, 51508, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious UDP Data'
Sat, 09/05/2009 01:28:13 - TCP connection dropped - Source:92.97.196.80, 64151, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:28:57 - TCP connection dropped - Source:89.228.230.46, 62881, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:28:59 - TCP connection dropped - Source:121.44.115.124, 2051, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:29:07 - TCP connection dropped - Source:88.96.6.153, 39842, WAN - Destination:208.190.133.203, 18074, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:29:57 - UDP packet dropped - Source:88.192.138.109, 26032, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious UDP Data'
Sat, 09/05/2009 01:30:05 - TCP connection dropped - Source:68.81.135.141, 58592, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:30:53 - TCP connection dropped - Source:66.41.16.130, 59026, WAN - Destination:208.190.133.203, 36177, LAN - 'Possible Port Scan'
Sat, 09/05/2009 01:31:15 - TCP connection dropped - Source:69.153.138.77, 4613, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:31:31 - TCP connection dropped - Source:138.231.141.223, 48877, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:32:11 - TCP connection dropped - Source:72.224.105.56, 60950, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:32:21 - UDP packet dropped - Source:83.251.198.188, 20157, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious UDP Data'
Sat, 09/05/2009 01:32:33 - UDP packet dropped - Source:189.70.60.62, 45682, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious UDP Data'
Sat, 09/05/2009 01:32:43 - TCP connection dropped - Source:98.22.242.41, 60947, WAN - Destination:208.190.133.203, 18390, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:33:09 - TCP connection dropped - Source:24.15.44.165, 3321, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:33:11 - TCP connection dropped - Source:72.28.189.59, 3492, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:33:23 - TCP connection dropped - Source:93.39.33.70, 51248, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:33:29 - UDP packet dropped - Source:87.202.75.142, 31816, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious UDP Data'
Sat, 09/05/2009 01:33:33 - TCP connection dropped - Source:66.192.38.117, 47919, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:34:21 - TCP connection dropped - Source:92.97.196.80, 64400, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:34:23 - TCP connection dropped - Source:83.145.243.65, 58327, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:34:25 - UDP packet dropped - Source:217.42.102.7, 52081, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious UDP Data'
Sat, 09/05/2009 01:34:29 - TCP connection dropped - Source:121.203.28.186, 54971, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:34:49 - TCP connection dropped - Source:69.153.138.77, 4827, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:34:55 - TCP connection dropped - Source:121.44.115.124, 2239, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:35:17 - TCP connection dropped - Source:89.228.230.46, 62231, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:35:25 - TCP connection dropped - Source:90.196.18.243, 59643, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:35:35 - TCP connection dropped - Source:213.46.73.149, 1603, WAN - Destination:208.190.133.203, 18389, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:35:53 - TCP connection dropped - Source:86.26.124.14, 3307, WAN - Destination:208.190.133.203, 24358, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:36:07 - TCP connection dropped - Source:71.227.97.224, 18005, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:36:29 - UDP packet dropped - Source:213.46.73.149, 21729, WAN - Destination:208.190.133.203, 18389, LAN - 'Suspicious UDP Data'
Sat, 09/05/2009 01:38:03 - TCP connection dropped - Source:67.173.42.112, 57484, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious TCP Data'
Sat, 09/05/2009 01:38:25 - TCP connection dropped - Source:188.60.252.50, 59899, WAN - Destination:208.190.133.203, 36177, LAN - 'Possible Port Scan'
Sat, 09/05/2009 01:38:43 - UDP packet dropped - Source:213.92.140.160, 40950, WAN - Destination:208.190.133.203, 36177, LAN - 'Suspicious UDP Data'
Rattlewagon
SW PA
Im glad you got it solved!
it looks like a bot somwhere is doing a heavy port scan...
I watch my firewall's outside interface somtimes at work and it astonishes me how much we get scanned!
