My m1008 runs alright, I think it needs a IP rebuild, has a miss and starts with lots of cranking and glow plugs when warm after sitting for more then 40 minutes. However today it would not turn off. The fuel -shut solenoid pink wire has power with key on and no power with key off. I would assume this is stuck in the open position becuase it is clearly not working properly as when the key is off truck keeps running strong. Pinched the fuel return line as TM said to turn off.
Anyone have the part # for the fuel shut off solenoid?
Any ideas?
thanks
Any ideas?
thanks
