I just got some bad news on my new M1009 rubbing problem. My mechanic friend is pretty sure it is a cracked crank shaft. I thought it was going to be a flywheel or bolt problem. He will know for sure tommorrow when he cleans it and checks it again. He said their is a wobble to the converter and flywheel that he thinks is caused by the crank.
My question is what should I do if it is the crank. Being a newbie to the M1009 and desiels in general? What will be the cost or best option. Replace motor? Replace just the crank? Any thoughts on the best place to get an engine or crank?
Thanks for any help.
