HELP m35a2 problems
bc35339
Mt.Washington KY
I just got this truck and it starts (with jump) and runs great the speed and rpm gauge works but nothing else works , no light inside or out and no other gauges work. Who else has had this problem and where should I start. Fuse or bad swicth or bad connection? what would cause all of this to quit working. It is much easier to ask you guys/girls then to start from scratch troubleshooting couse im not to good at that.
Thanks for any and all info..
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
You said you had to jump it to get it to run. If the alt doesn't get 24v to excite the charging circuit, you won't get nothing. Check your batterys first.
980
24
Dover, New Hampshire
Check to make sure you aren't overwhelming the system either. When I first installed my rotating convoy lights I woud run them for a few mins and then half my electrical system would go dead. I would turn off the switch and the service drive, then turn just the service drive back on. Everything would be fine again as long as I didn't run the convoy lights for too long.... still a mystery to me, but my guess was that they were running with the truck at idle and the lack of jiuce coming from my generator would cause an overload if everything was on. Check your generator and your batteries.
dittle
72
Albia, IA
I had a truck do the same thing, bad/dead batteries were the cause. Do like Gimpy said and start there.
kc5mzd
Texas
First I would test the obvious main power switch. Then there is a series of wire junctions (inline plugs) under the dash that get power from the starter. They are what powers everything. I would start unpluging them 1 at a time, cleaning and pluging them back in with a good electrical grease.
deathrowdave
80
falmouth, ky
Not sure but i think all gauges are controlled from 1 main power feed (spider harnass). It could be un plugged . Check grounds , just as Gimb instructed you to you need a VOM to check voltage and grounds. Good luck,Dave
kc5mzd
Texas
If the lights/guages work when it is being jumped (cables connected) and then don't when the cables are disconnected then I would suspect an open cell in a battery. If this is the case then I would just replace the batteries and that would likely fix it.
