Help me install a 10K Garwood winch on my M109
lelandEOD
Reno, NV
Hey folks,
I've got a Garwood 10K PTO winch I'd like to install on my M109 and I *think* I just need one or two parts to get it up and running. Can those of you with running winch set ups tell me if I have everything I need to get this connected? I'm kind of doing this piecemeal so any help you can offer will be most appreciated!
So far, I've got the centerpiece... a 10K Garwood winch:
The back of the winch has this input shaft:
I also have a driveshaft with the shear pin on one end that I think connects to the winch input shaft:
The driveshaft looks complete:
lelandEOD
Reno, NV
So here's where I need some help.
My PTO output seems to be lacking a companion flange to connect to the driveshaft.
Here's a shot of what I'm working with:
And here's what I *think* is the PTO end of the winch driveshaft:
Hmmm... so it seems to me that I need a companion flange on the PTO output shaft to bolt up to the driveshaft. A google search yielded a couple different possible parts, but this is the one I think is correct:
Am I on the right track here? I still need to service/rebuild the winch itself and refresh the driveshaft U-joints and slip joint, but am I missing anything else?
I tossed the old wire cable as it was a frayed tetanus shot waiting to happen... any recommendations on a replacement cable? ...length, capacity, etc?
M37M35
648
East Central Oklahoma
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
You're on the right track!
You might call Erik's and confirm, but I'm pretty sure that's the right one.
And it is not...
See this old post for the correct dimensions...
Edit to add: Just finished checking out all the "usual suspects"... looks like that part can be added to the Deuce-hard-to-find items, nowadays.
But there it at least one possible source: https://www.ebay.com/itm/133267069542
(yes, posting eBay links is allowed now...;))
M37M35
648
And it is not...
I stand corrected! Thanks for chiming in, you're a wealth of information!
Now I'm curious... Do you know what the above flange actually fits, if anything? Erik's Surplus seems to give the impression it will work with the winch...
Is this the correct flange? Seems pricey for what it is...
Also, I know the older deuces, I think with gas engines, used a different driveshaft with a plain yoke instead of a flange. Could a person do away with the flange on the later model driveshaft and replace it a yoke? I wonder if this is the yoke for the earlier winch driveshaft?
Good to know!
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
No, I don't... That 2-1-333 flange may work for a M35 (gasser) if one wanted to use the A2 driveshaft, which already comes with the required 2-2-329 flange yoke.
But for a M35A2 it sticks too much out, so that the OP's stock (Multifuel) driveshaft would bottom out even before it could be installed.
Close... The keyway should be 5/16" wide, not 1/4". Probably a typo (?); it actually looks wider in the pictures.
Not. Besides other modifications, the gasser's driveshaft uses a 2-4-663 end yoke that goes on the PTO shaft, instead of the companion flange.
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
Well, I snagged the one on eBay...
That one probably comes without the set screw, so you will need one like this one....
It looks like your PTO output shaft is missing its key.
If you don't have it already, it takes a 5/16" x Ø 1.0", round bottom key (flat bottom will work, also). Search for "1008 Woodruff key".
Correct dimensions, shown below:
lelandEOD
Reno, NV
This is awesome, thanks! Grainger here I come!
