Finnegan1008
- 163
- 43
- Connecticut
I would like to drive my m1008 over 55mph on the highway and am weighing out pros and cons of various options. I want to keep the truck as true to form and original as possible with the exception of some aggressive off-road tires (in the 32” range) and highway gearing.
The truck will remain stock otherwise. Please weigh in your opinions and experiences with the below options. (Or any others Ive missed)
re gearing the axles:
Pros - truck remains completely stock and I can keep the stout (and perfectly good) TH400
Cons - re gearing means new carriers which is pricey.
Questions- Would I be giving up some low end grunt with the setup?
700r4:
Pros- cheap and somewhat straight forward, stock drive shafts, stock mounting hardware, same dimensions as the TH400 ect
Cons - durability especially when towing and TV cable mounting is not and exact science and can lead to catastrophic failure
Question- is the durability concern blown out of proportion? Can these be built to be really stout?
4L80e:
Pros - stronger than the 700r4
Cons- expensive, not the same size as the TH400 so drive shaft mods needed, linkage won’t bolt up, shift Column needs replacing or modifying. Needs a computer
NV4500:
Pros- manual transmissions are awesome, gearing is great for this platform. Same dimensions as the TH400 (I think?). It’s a strong setup
Cons- expensive, lots of junk yard searching, pedal setup is hard to find, changes the concept of the truck.
gear vendors OD:
Pros: bullet proof, simple, and keeps the truck basically stock
Cons: pricey
Again please school me on my logic here, trying to figure out the right option.
700r4:
4L80e:
NV4500:
gear vendors OD:
Cons: pricey
