Help Me understand
APM215
9
Bradford. ON. Canada.
I figured I would do this right rather then hijacking someones thread.
Help me understand how the Bridge Plate works what do the numbers 0-9 mean?
What Do the Letters mean?
Do I put one on a Trailer too or Is one on the truck enough?
Help me Pleases!
I stole this pic from a thread on the topic hope no one minds.
CCATLETT1984
Saint Clair Shores, MI
you have just the plate on the truck, when you have a trailer in tow, you show the C on the top plate.
The numbers are the "class" of bridge (weight capacity) that is required for the vehicle to be able to safely cross.
I forget which, but one of the Tech Manuals explains the use of the bridge plate.
DanMartin
Hillsboro, Oregon (USA)
I always was told the numbers rounded up to the nearest ton of weight. An unloaded deuce (aprox 13K lbs) would show a "7". Loaded completely (approx 23K hwy) would show a "12", etc. Weight is combined (C) if a trailer is towed, hence the "C" addition.
Someone please confirm this for me....it is what I have been told but I cannot point to documents to verify it.
WillWagner
2,704
Monrovia, Ca.
I think there is a good explanation in the 10 or maybe one of the operator level 20 manuals. Give that a look see.
jasonjc
289
Gravette Ar.
for the deuce look at page 1-16 of the 9-2320-361-10 list the class numbers for the deuce's. FM 5-36 has more info.
CliffW
Mims, Florida
Re: RE: Help Me understand
:ditto: this will help you understand how it works.
swbradley1
Modertator
1,705
Dayton, OH
RE: Re: RE: Help Me understand
It would have been okay to hijack my thread. I just want the bridge plate so I can 69 on the front of the truck.
I've heard that's on most trucks. ;-)
dm22630
42
Front Royal, VA 22630
Re: RE: Re: RE: Help Me understand
If your lucky....its on the grill & in the back ;)
Jones
Sacramento, California
When you're towing a trailer or another vehicle display the "C"; it stands for "Combined"-- the total of the two pieces. Otherwise the blank side should be displayed.
The weight should be shown as a digit or digits denoting the gross weight (empty or loaded) in 1,000's of pounds. i.e. 13 would be 13,000 pounds.
Look over this bulletin; www.wood.army.mil/cellx/information folders/mil load class/mlc web document.html , it should be of use to you. Find your vehicle on the left of the chart then look across to the chart's MLC E/L column; it has the figures for your vehicle.
saddamsnightmare
80
Abilene, Texas
July 5th, 2008.
On the Multifuel M35A's, the passenger door was stencilled with an 8 in a circle for the bridge weight, the front bridge plates would be 06 for gas deuce empty, 07 for Diesel deuces empty, add 3 for off road load, 5 for on road load, plus "4" for M105A2 loaded trailer, which means:
Gas Deuce 06 +trailer = C08
"do" loaded off road 09+ trailer (04)= C11
"do" load Hwy 12 + trailer 4 = C16
Diesel Deuce 07 +trailer = C10
Diesel Duece off road load 10 + trailer + C14
Diesel Deuce Loaded 12 + trailer +C16
David Doyle's magnum opus "Catalog of Standard Military Vehicles", in Appendix "A" or "B" explains the uses of the bridge plates and the numeral designations used. The U.S.Army considered that the rolling deuce had a lesser bridge weight rating then you would suspect, due to the axle spacings and dynamic loads... BUT it is safe to say that I would not cross a 4 or 5 ton rated bridge with any deuce, loaded or not.....
The M105A2 trailer carries only a stencilled "4" in a circle on the front right side panel, establishing it's loaded bridge rating at 8,000 lbs (2,750 trailer weight + 3000 off road = 6000 lbs, on road 8,000 lbs (2,750 + 5,250 cargo). Other combinations would weigh accordingly, and I have seem military M35's in movement with no numbers or insignia on the bridge plates wheen running empty stateside.
All Hail David Doyle, the Great and Powerful Wizard of the military vehicle collectors fraternity.... I can't wait until he gets out the work on the G742 series (M-35 trucks).....
With great respect and regards,
Most Sincerely,
Kyle F. McGrogan rofl
