Help needed chicken shield and riser
Drjduff
Phoenix, Arizona
Any help would be surely appreciated. The problem: I need a pintle riser that has four bolts for the chicken shield and is wide enough at top to mate with the mk64 cradle for the m-2.
BLK HMMWV
497
Pasadena California
what kind of shield do you have ?
is it flat or does it have a bend in it.
Not sure what you mean by wide enough to mate with the MK-64 cradle?
The Mk-64 cradle uses a small pintle.
Your best bet is to try 86humv here on the boards.
Do you already have the M2 adapter for the MK-64 because you will need that also if you don't have it already
Drjduff
Phoenix, Arizona
Yes, it does have the bend in it (Shield). I need the small pintle for my systems bu I don’t know of a 50 cradle that has the small pintle male end.
I’m really new to this and don’t know what 86hmv is
Sent from my iPad using Tapatalk
BLK HMMWV
497
Pasadena California
The MK-64 cradle has a small pintle on it already.
It fits in the UPA (Universal Pintle Adapter)
You are looking for a UPA for a shield (flat rectangular plate on the face) that also has a yoke on the back of it ( adjustable Y shaped piece with a cross bar for the T&E Mechanism )
86 HUMV is a member here on the board who might have what you need
A picture of the parts you have would help.
You sure you have a MK -64 cradle ? and not a MK-23 cradle?
BLK HMMWV
497
Pasadena California
The only person who is going to have the pieces your missing off the UPA is 86 humv.
You may have to buy a complete UPA from him if he has one. Sadly it is a common method of de-milling them to separate the back half of the UPA.
The Mk-23 cradle will work on your HMMWV but just not with a shield.
They make 2 different cradles that will work with that style shield and UPA.
A Mk-64 and a Mk-93
The MK-64 requires an adapter to adapt it to the M2
The Mk-93 doesn't
The Mk-93 is buffered as well .
BLK HMMWV
497
Pasadena California
I'm surprised he hasn't found you yet.
on the top of the page you will see the word MEMBERS
click that scroll down a ways and it will say find member.
Type in 86humv and then I believe it will say something like start a conversation.
