Help needed/truck stuck - Cycling pneumatic relay under PDP in 2000 M1088 w/3126
ckouba
1,724
Oregon
Need some help from the forum's collective knowledge....
Took my truck ~100 miles yesterday to Eugene to have the habitat structure blasted and painted. Drive down was hot with a bit of traffic but went smoothly. The fan cycled a bit more than expected but ran everything ran fine despite my nervousness. No reasons to think anything was going to go wrong.
Got to the shop and took about an hour and a half to unload the camper. Went to move it out of the building and park it and everything started fine, but after ~10 seconds, what I presume to be a relay started to endlessly cycle. I presume it's pneumatic because by the time we had driven across their lots to park the truck, the low air alarm had started whining.
The relay sounds like it's located below the PDP behind the kick panel but I didn't have time to troubleshoot because we were already past closing time, the shop was closing up, and I needed to get out of there. I was also out of daylight.
I am back home, ~100 miles away, and need to head back and get it running. I will start poking through TM's but if anyone has a strong idea of what is happening and how to resolve, please drop a note here.
Thanks!!
Skyhawk13205
268
Alaska
Thanks!!
Sounds like your fan solenoid. Good luck
ckouba
1,724
Oregon
Should also say that someone went out and tried the ignition this morning and the solenoid is still clicking after everything cooling down overnight.
Ronmar
7,442
Port angeles wa
Unplug your CTIS controller and see if that stops it. You can also turn on the fan fording sw to see if that stops it. If it is cycling regularly it is probably the CTIS…
If CTIS STOPS IT, just leave it unplugged and check your tire pressures and drive home. If the fan sw stops it remove I believe CB 22 which should keep the fan engaged for the drive home….
ckouba
1,724
Oregon
On site.
Turned on ignition. Still cycling, 2x/sec or so.
Unplugged CTIS controller, all good.
Does that mean my controller just took a dump?
ckouba
1,724
Oregon
Starting to scour TM's but if anyone can point me to the correct one, I would appreciate it.
ckouba
1,724
Oregon
Ronmar - I didn't note this when I was down there but it was in HWY mode and I think the indicator was flashing (just that one). Maybe the HWY and RUN FLAT. I am forgetting now. It was doing something though, not just all dark.
With the truck functional enough to get home, I called it a day and drove back to Portland. I will bring a hose and air chuck with me when I pick it up and make sure tire pressures are good and then drive it home.
I've been poking around and have found something for CTIS troubleshooting: TM 9-2320-365-20-2; section 2-24, page 2-1767
Step 6 tells me to "Repair or replace manifold valve assembly (para 12-7)", so now trying to find that...
Thanks for the pointers this morning!! Glad it will still get itself home.
NDT
6,489
Camp Wood/LC, TX
"Find" as in a new one or on the truck? You know, could there be a possibility that they poked a hole in a tire? The system is supposed to keep the tires at pressure and overcome small leaks.
ckouba
1,724
Oregon
Not quite sure what your question is NDT. I will look at the CTIS component behind the pass kick plate to see if there is something mechanical wrong with it. Someone on the FB group suggested that, along with a servicing of the dryer.
ckouba
1,724
Oregon
Forgot to mention the tires were all holding air. They were still robustly inflated when I got back down there today.
ckouba
1,724
Oregon
FYI - Thanks for the help, got the truck home today with the unplugged CTIS. Will take a look at the manual conversion set up before diving through the troubleshooting process.
