vegavairbob
- 1
- 3
- Brookhaven NY
Purchasing a rust-free M1009 but unfortunately it was converted to a 12 volt system (I hope it was done with the one-wire method)
One non original alternator is currently used on the drivers side. Current owner bought the truck converted and it starts and runs fine.
One original HD alternator comes with the truck which leads me to believe one alternator had failed as current owner only has one of the original alternators that wasn't hooked up.
Both batteries are still in it. Not sure how they are hooked up. I believe one battery is not.
Please help with diagnosing what was done (or what would have to be done to convert to 12 volt starting/charging) and how to put it back to 12/24 (besides getting another HD 100 watt alternator (and installing both HD alternators.).
Thanks in advance.
Also the glow plug light is out and a manual toogle switch is used. Id like to hook that up correctly as well with a working glow plug light.
In all cases would the 24 volt starter have to be removed to convert it to 12 volt starting? meaning do I need a 24 volt starter in addition to replacing one of the missing HD 100 watt alternators?
Thanks in advance.
