HELP - Newbie in over his head
rjinga
Monroe, GA
Help! I've got the driver door off my '85 M1009 (unbolted door from hinges), so that I could get to the hinge pin more easily to replace the bushings. But it looks like the pin has some sort of flange on the bottom?
How do I get the pin out?
Ripcord01
9
Waldorf ,Maryland
I use the tool designed to remove the pins. It named a hammer and a chisel followed by your favorite cold beverage and a few curse words..Watch the fingers when using hammers.[thumbzup]
waayfast
106
Lake Fork,Idaho
UUHHH! Dang! too late kinda--------whenever working on door hinges on a vehicle,if you take a pencil(pen works too) and scribe the outline of the hinge before removing the door it will make getting the door installed a LOT easier.With scribing you just put it where it belongs and tighten the bolts.Without scribing you may be ALL day and a shop full of bad words trying to get the door to line up so it shuts correctly and it does'nt whistle at highway speed.
Vet89
Cedar Rapids, Iowa
" HELP - Newbie in over his head "
I feel like that often! Bless the folks here - reading the posts in this site leaves me amazed at the skill and expertise of members here and* that they are willing to give advice. /slaute
