ida34
- 33
- 48
- Dexter, MI
I got a chance to check out my truck today. I really lucked out. Thanks for all the feedback about checking the fluids. Everything was fine. I will have to put in some lube in the front diff and the Radiator. I had trouble when I got to the master cylinder. Instead of the plug I expected to find I found a plug with a 90 degree angle connector on top that connected to a small metal line that went to a tee attached to a large metal line that seems to connect to the airpack. I think I can disconnect the line then take the plug out but hate to do that without knowing what the line is for. Any suggestions? Anyone know?
Chuck
Chuck
