Help replacing ip...
anthonyamato4
somerdale nj
I need to change the IP on my multi fuel and I can't seem to clear across how to do it....any one able to steer me in the right direction on this one? I have an LDS pump to put on my LDT engine...anyone that can help me with steps on what to do please help.....thanks!!
sandcobra164
295
Leesburg, GA
I wish you were closer, I could have it done in a few hours. If you run into trouble, post back up, I'll do my best to talk you through it. Have you downloaded the TM's? They help alot but sometimes you just need to talk to someone. Let us know.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Line up the harmonic balancer on the ldt timing mark. Pull the front valve cover to make sure the valves are closed, indicating TDC. Look in the IP's advance timing mark window(the little window with 4 bolts just in front of the HH under the T fitting). There should be what looks like an ice pick tip sticking out. That will point to a slot on the round disk in front of it. When those are lined up, take the old IP off.
Install the new IP with the timing marks in the same spot, your done.
Just so you know, there are 3 bolts on the IP's gear, you can loosen those to help install the ip and move the timing to line up, then tighten them up.
Sound ok?
I cannot provide pics, as I am not at home, sorry.
